Date/Time: Mon, 20 May 2024 00:18:06 +0000
TAS MArket map slowing dow charts
View Count: 1168
[2019-02-24 18:22:11] |
Warren Springer - Posts: 3 |
Good Day I am having a problem with my charts becoming really slow when i have my TAS market map on. Is this a known problem and is there any way to solve it? Thanks |
[2019-02-25 00:07:49] |
This must be a custom study you are referring to. First thing we want you to do is to run Sierra Chart in Safe Mode and see if that corrects the problem: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-05 13:26:14] |
Hi yes correct these are custom studies, from TASmarketprofile. When i open up in safe mode the studies are no longer displayed on my charts.
[2019-03-05 17:43:28] |
If you have any problems with those custom studies, then contact the developer about them. Refer to help topic 17 as well: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
