Date/Time: Sat, 18 May 2024 22:03:38 +0000
System slowed down significantly
View Count: 483
[2019-02-21 15:17:12] |
tdug - Posts: 124 |
Hi, I have recently connected SC to my TD Ameritrade data feed for US equities analysis. I have been using it for futures data with a rithmic feed. The system runs very slow and laggy on the TD Ameritrade feed. Simple scrolling etc is slow, buttons have about a 5 second delayed reaction. Wondering if I have too much data loaded for each symbol or what the issue may be. Many thanks. Log as below. (Message log removed) Date Time Of Last Edit: 2019-02-21 18:45:45
[2019-02-21 18:45:26] |
The Message Log is not helpful in a case like this. Refer to this help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
