Date/Time: Sun, 19 May 2024 14:54:56 +0000
2 brokage accounts
View Count: 713
[2019-02-19 08:45:29] |
User132871 - Posts: 14 |
I currently have my futures account linked to SC. How can I add my forex account as well? I would like to trade futures and fx from 1 platform similar to NT. Please advise.
[2019-02-20 19:39:56] |
You need to use a separate (Second) instance of Sierra Chart. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-20 19:40:07
[2019-02-20 20:41:51] |
That's inconvenient. Any plans on changing that?
[2019-02-25 13:51:52] |
any update on this?
[2019-03-06 14:55:40] |
any update on this?
[2019-03-06 23:27:38] |
In general this would not be supported. The only thing that might come would be combining this service: Sierra Chart / Trading Technologies Futures Order Routing Service With a very specific Forex trading service but when that would come we do not know. It is not likely to be for a long time if at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
