Date/Time: Fri, 03 May 2024 14:42:47 +0000
Managing SC Feed Realtime Symbol Limits
View Count: 805
[2019-02-18 03:53:10] |
User379468 - Posts: 508 |
I only need real-time data for a small handful of symbols at a time, 3-5, but work with a large total number of symbols with historical data, 30-40+. How can one set/control/change which symbols are set to receive realtime data and which are set to receive delayed data, to remain within the 20 symbol limit and continue working with larger amounts of symbols using historical data? |
[2019-02-18 16:11:33] |
All symbols would receive real-time data. Refer to this documentation here: Chart Data and Chart Data Files: Reducing Number of Symbols Being Tracked by Sierra Chart Also we expect in about three months to be able to significantly increase the symbol limit for CME real-time data with the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-18 16:12:33
[2019-02-18 17:55:53] |
If it could be possible to set/manage the symbols receiving RT, it would be useful to lower unnecessary higher fixed monthly costs of the higher symbol limit feed options.
[2019-02-18 18:05:09] |
No but this is not going to matter after about 2 to 3 months.
[2019-02-18 18:30:40] |
Do you mean that at that time not only will the limit be gone, but the cost will be lower also?
[2019-02-18 22:38:37] |
Yes amazing what we are able to do when we become a direct market data vendor and then we hope users can begin to see why it is it is important that we begin to concentrate the bulk of our users onto our upcoming single unified order routing solution so that there is enough money to pay for all of these improvements: Sierra Chart / Trading Technologies Futures Order Routing Service This is a gradual process and we are not here to force anything, at least not in the near term. And only until the solution has proven itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-18 22:40:22
[2019-02-19 00:58:31] |
Acro - Posts: 436 |
Sounds good. As long as we can still execute off Interactive Brokers until there is a feasible replacement for global customers |
[2019-02-19 01:34:43] |
We are not going to remove support for Interactive Brokers.
