Date/Time: Sat, 04 May 2024 15:26:25 +0000
time line study not showing up on charts
View Count: 903
[2019-02-15 12:01:22] |
User714832 - Posts: 2 |
Being with sierra for 10 years. Being trying to add TIME LINE study to chart. I am able to get them to show up on studies but not showing up on charts!! |
[2019-02-15 19:34:02] |
We need to get that particular chart from you by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart And then we will see what the issue is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-03 16:48:16] |
The time line indicator does not work or show up on charts. I have attached the chart as well as a jpg of the settings i use. |
Chartbook7.Cht - Attached On 2019-03-03 16:42:18 UTC - Size: 118.72 KB - 238 views Timeline Settings.JPG / V - Attached On 2019-03-03 16:46:55 UTC - Size: 164.55 KB - 225 views |
[2019-03-04 00:17:11] |
You need to set the Draw Style for Subgraph 1 on the Subgraphs tab for the Time Line study to Bar Top: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-04 00:18:05
