Date/Time: Sat, 27 Apr 2024 20:55:06 +0000
Time Range Highlight to color volume bars Chart Region 2 (or chart region other than 1)
View Count: 1208
[2019-02-14 23:31:24] |
User642217 - Posts: 10 |
I am using Time Range Highlight to color my candlestick bars in main price graph (chart region 1) for 2 hour periods. How do I color my Volume bars in chart region 2 to match main price graph using Time Range Highlight? I can't setup the Time Range Highlight study correctly to color the volume bars. Is there another way to make volume bars match color of main candlestick? |
[2019-02-15 07:10:25] |
You can use the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-15 23:07:20] |
I does not work for volume bars. So I have a study for the candlesticks and one for the volume bars. I want color of candlesticks and volume bars to match for defined time period.
Chart1.png / V - Attached On 2019-02-15 23:03:11 UTC - Size: 28.59 KB - 359 views Settings.png / V - Attached On 2019-02-15 23:03:24 UTC - Size: 40.18 KB - 274 views Subgraph.png / V - Attached On 2019-02-15 23:03:51 UTC - Size: 43.4 KB - 271 views |
[2019-02-15 23:43:24] |
Attached is a Study Collection that does what you want. The trick is to set the Color Bar Based on Alert Condition to be based on the Volume study, and then set the alert to test against the Time Range Highlight. For information on how to use a Study Collection, refer to the following: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
PriceVolumeTimeHighlight.StdyCollct - Attached On 2019-02-15 23:43:20 UTC - Size: 28 KB - 302 views |
