Date/Time: Fri, 03 May 2024 08:56:08 +0000
Horizontal Ray tool help
View Count: 913
[2019-02-14 23:15:47] |
sierra - Posts: 22 |
Hi Please let me know if there is anyway to have a dot (larger than the line itself) at the start of a horizontal line. When I place it at the top of a bar its starting location is invisible, especially when there is a double top bar. Even when chart I have read through all the documentation but am not finding the answer I need. This even happens when I de select draw non heighted drawings under main graph and studies. Thanks Kurt |
[2019-02-15 16:36:41] |
John - SC Support - Posts: 31334 |
It depends on exactly what drawing type you are using. If you are using a standard Line drawing, then you can turn on the Markers at the beginning or end of the line. Refer to the Mark items within the following documentation: Chart Drawing Tools: Line | Ray | Extended Line Configuration Also, you can force a Line, Ray, or Extended Line drawing be Horizontal or Vertical by using the Control key when you draw. Refer to the section Making a Line either Horizontal or Vertical within the following section: Chart Drawing Tools: Line, Ray, Extended Line For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
