Date/Time: Tue, 07 May 2024 20:42:56 +0000
Back testing - possible data compression
View Count: 594
[2019-02-14 15:17:57] |
User528369 - Posts: 5 |
Dear Sir, Madam, Im currently using the backtesting option on my demo account to test a strategy. That works good, but I feel like price and volume data are getting "compressed" the more I go back into the past (historic data). Is this correct? Does the tick data get compressed? If so, could you please tell me, how many days I can go back using the real tick data? I'm doing the back test for the CLH9 future in a Numbers Bars chart, so I'm using the trades volume on the bid and ask side for my test. As the data provider I'm using Rithmic. Kind Regards |
[2019-02-16 17:30:33] |
You need to set the chart to a continuous futures contract chart: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
