Date/Time: Wed, 01 May 2024 23:42:03 +0000
Gap issues
View Count: 690
[2019-02-14 12:44:24] |
Vladislav Kravchenko - Posts: 39 |
Hello, would you please help me with the following problem. I am trying to find how to fix a gap with a Gold future contract. I was trying to solve the problem with many ways: - deleting and reloading data for the last 2 months; - changing rollover rule; - changing days to load; But nothing helped. The time zone I am living in is +3 UTC (based in Moscow), I have checked the session time as well. Now I am confused how to fix a gap. Some screenshots are attached. |
Prob 1.png / V - Attached On 2019-02-14 12:43:16 UTC - Size: 86.85 KB - 303 views Prob 2.png / V - Attached On 2019-02-14 12:43:22 UTC - Size: 89.46 KB - 249 views Prob 3.png / V - Attached On 2019-02-14 12:43:26 UTC - Size: 86.36 KB - 236 views |
[2019-02-14 12:46:24] |
The gap is between 02.28.19 and 02.29.19.
[2019-02-14 18:54:07] |
We do not know what gap you are referring to. And also the dates you mention are at a future point in time.
[2019-02-15 08:04:19] |
Ok, I have made a mistake. The exact dates are between 28 and 29 January. Would you please tell me how to avoid gaps in the future and which rollover rule is the most accurate? |
[2019-02-15 18:14:11] |
Okay so that particular price gap can be corrected by using one of the back adjusted continuous futures contract rollover options: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-15 18:16:34
