Date/Time: Mon, 29 Apr 2024 09:48:44 +0000
How to move chartbook tabs?
View Count: 1373
[2019-02-13 06:39:59] |
User493712 - Posts: 11 |
Is there a way to move and rearrange the order of chart tabs in a chartbook? It looks dragging a tab has no effect. Thanks.
[2019-02-13 07:13:24] |
User90125 - Posts: 715 |
If you're referring to the chartbook tabs that are normally at the top, click and drag works for me in v1874. https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#ReorderingChartbookTabs |
[2019-02-13 15:43:48] |
As mentioned dragging the Chartbook tabs or Chart Tabs will allow you to change the order of these items. For the Chart tabs, you can also rearrange them by selecting Window >> Windows and Chartbooks. You will find the information on tabs and how to rearrange them here: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#WindowAndChartbookTabs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-13 17:32:12] |
This works, but dragging chart tabs does not work for me.
[2019-02-13 17:57:16] |
This kind of problem would typically be related to the Operating System that you are running. The ability to drag tabs is relatively new and it could have a problem with an older OS like Windows XP or Windows 7.
[2019-02-13 18:01:50] |
Makes sense. My SC is running in Wine on Mac.
