Date/Time: Fri, 03 May 2024 01:32:56 +0000
Several instances of where Sierra_64 stopped working pre-release 1871
View Count: 697
[2019-02-11 12:54:07] |
IconBob - Posts: 61 |
I'm sending screenshots of error message just to be sure it's windows and not Sierra. I'm going to upgrade to 1872.
2019-02-11_7-41-58.jpg / V - Attached On 2019-02-11 12:50:26 UTC - Size: 178.6 KB - 320 views 2019-02-11_7-42-46.jpg / V - Attached On 2019-02-11 12:50:44 UTC - Size: 181.2 KB - 248 views 2019-02-11_7-43-39.jpg / V - Attached On 2019-02-11 12:51:02 UTC - Size: 186.23 KB - 344 views |
[2019-02-11 19:35:32] |
We believe the problem is due to some custom studies you are running because we see in this screenshot some overlapped windows which are not natively part of Sierra Chart: https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=25905 Run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-12 12:35:56] |
I haven't had the problem since I reported. I'm only running one custom study that I'm aware of and if I continue to have problems I will contact the developer.
Date Time Of Last Edit: 2019-02-12 13:04:47
[2019-02-12 17:47:30] |
You will need to run in Safe Mode to see if the problem goes away so you know if it is caused by the custom study. Most likely.
