Date/Time: Mon, 29 Apr 2024 01:55:12 +0000
Precision Select
View Count: 738
[2019-02-09 20:34:55] |
User257019 - Posts: 25 |
Hello team, From this documentation, it says "When a Trade DOM window is attached to the main Sierra Chart window, the standard Normal Select pointer will always be used. ": Chart Drawing Tools: Controlling the Type of Pointer Displayed When Using Drawing Tools I have the trade options as in the attached file and I still see the Normal Select pointer (not the Precision Select). Is that configuration ("Attach Trade Window To Chart") considered as a DOM window? If you are manually trading is not that cool to use the Normal Select :( Thanks! |
trade_config.PNG / V - Attached On 2019-02-09 20:32:18 UTC - Size: 39.56 KB - 228 views |
[2019-02-10 20:50:15] |
Is that configuration ("Attach Trade Window To Chart") considered as a DOM window? No.To use the cross type of pointer, you just need to enable the Chart Values tool: Chart Drawing Tools: Chart Values/Crosshair Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-10 20:50:37
[2019-02-11 12:21:53] |
Hello team, Unfortunately that´s a configuration I usually have selected and it´s not showing the cross type of pointer, I always see the white pointer. Attached two images: 1. You can see from the config that Chart Values is selected. 2. A demonstration that the white pointer is present while Chart Values Tool button is selected. FYI: I had to take a picture with the mobile phone because using PrintScreen or Snipping Tool was removing the pointer. Thanks and Kind Regards. |
ChartValues.jpg / V - Attached On 2019-02-11 12:21:31 UTC - Size: 18.9 KB - 246 views IMG_3082.jpg / V - Attached On 2019-02-11 12:21:46 UTC - Size: 417.81 KB - 233 views |
[2019-02-11 18:46:48] |
This would have to be a change in your Operating System Mouse properties that the Precision Pointer is now set to the arrow. On standard Windows 10 you would find these selections by going to Settings >> Devices >> Mouse (on left) >> Additional Mouse options (on right) >> Pointers Tab (on Mouse Properties window). If that does not help we cannot provide further help with this. It is not within our control. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-12 09:31:13] |
Hello team, I´ve confirmed that renaming Sierra3.cfg to for example Sierra3.old and letting it to create a new file makes it work. This means it´s related to a configuration inside Sierra Chart, not related to the OS. However, the look and feel changes and I would like to make it work with my old config if possible. I was about to compare both files (working and non-working) but just realized it´s a bin so only you would be able to do so. I´m attaching the working Sierra3.cfg and the non-working Sierra3.cfg for you to check on my behalf please, if you would be so kind. Thanks! |
Private File Private File |
[2019-02-13 15:52:37] |
This is the result of having Global Settings >> Tool Settings >> Chart Values >>Always On When Chart Values Tool Selected enabled.
