Date/Time: Thu, 02 May 2024 04:42:55 +0000
Replay Processing Speed - Replay not working. Version 1872
View Count: 632
[2019-02-09 14:04:14] |
User104854 - Posts: 441 |
I just downloaded this version and I notice when I use the accurate replay feature it asks for the processing speed setting. The default is 60. It seems like no matter what setting I use, the replay is very choppy and not as fluid as it was with version 1852. In that version there was never a window that came up to enter the processing speed. Is there a way to disable this processing speed window? If not then what setting do I need to set it at to have it run the way that it ran with version 1852? I want it to run as smooth as possible on every trade and not stagger every few seconds. Thanks. |
[2019-02-09 14:15:57] |
I've looked and there is nothing anywhere that describes the settings for the processing speed. Can you guys just remove the window and go back to the way it was on version 1852? The replay feature for Sierra has always been very good in my opinion. Great for backtesting. With this new feature the replay function has taken a few steps backwards. If you won't remove it then let me know how I can get this to work just the way it did on the previous version. I asked this question about a month ago and did not receive a response. Thank you. |
[2019-02-10 21:58:35] |
and I notice when I use the accurate replay feature it asks for the processing speed setting. This is because there is a multi-chart back test being performed. If you do not need to perform back testing, then set the Replay Mode to Standard Replay:https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayMode In this case you will no longer get that prompt. And that type of back testing will not be performed. Also this is nothing new. This has always been there but the problem was is that when you were doing a replay for linked charts only rather than specifying all charts in the Chartbook the prompt was not displaying and it should have been. That was a mistake. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-10 22:07:31
