Date/Time: Sun, 28 Apr 2024 21:31:40 +0000
numbers bar text
View Count: 613
[2019-02-08 18:01:40] |
User968625 - Posts: 256 |
I would like to to remove the text bar text, first option in numbers bar study setting, but keep the whole configuration. for example, I want to still see only dominant side when "percent compare thresholds" meet my input. Hope that make sense. I don't want all the numbers but only what I want from this selection as well from other setting I chose to display
[2019-02-08 19:53:15] |
This is not within the scope of our support to help with but you can try to do this by adjusting the Threshold inputs and the color settings to cause the text that you don't want to see to be the same as the background color. Here is the documentation for Numbers Bars: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-08 19:53:31
