Date/Time: Thu, 02 May 2024 19:17:40 +0000
VolNumberText in DOM
View Count: 764
[2019-02-07 10:13:03] |
nicktrader - Posts: 665 |
Pls take a look at the pis. The marked Number is not really clear. Is there a way to change the fonts?
VolNumberText.png / V - Attached On 2019-02-07 10:12:06 UTC - Size: 10.94 KB - 262 views |
[2019-02-07 16:13:19] |
You need to change the study display order. And make sure that the study displaying those lines is below the Volume by Price study. Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-08 04:18:08] |
I am using only one study (VbP).
[2019-02-08 22:08:23] |
John - SC Support - Posts: 31328 |
First, we are not able to reproduce what you are seeing. We would like to get a copy of your Chartbook that includes the Trading DOM so we can see what the particular settings are that are causing this. Refer to the instructions here for attaching the Chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart Second, to change the font size for the text on the Volume by Profile study, refer to the following: Volume By Price Study: Volume Numbers Text Color and Size (SG7) Also, the font that is being used is the Chart Text Font (the font size is controlled as noted above). The following documentation shows where to change this, but it will affect all the text in the charts: Graphics Settings: Fonts and Text Appearance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
