Date/Time: Sun, 19 May 2024 06:58:26 +0000
Chart Hangs / Freezes in Sierra when i change the symbol to ES
View Count: 552
[2019-02-06 22:12:53] |
We would recommend not linking so many charts together and referring to help topic 30 for suggestions to reduce CPU usage: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often We recommend using a completely separate Chartbook for ES. And then switching between Chartbook's. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
