Date/Time: Thu, 09 May 2024 18:07:49 +0000
chart drawings extend only per day
View Count: 583
[2019-01-30 16:39:09] |
User903853 - Posts: 2 |
hello is there anyway that I can have my chart drawings (zones) only extend for that day/night session and then as I need I can change my zones and still see how they compare to the previous days zones
[2019-01-30 18:30:46] |
You could use the Rectangle drawing tool and make adjustments as needed. Refer to: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle This is the only way to do this. It must be done manually. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-30 18:31:25
