Date/Time: Wed, 15 May 2024 22:17:41 +0000
TD Ameritrade Data
View Count: 1234
[2019-01-28 23:03:15] |
MM1187 - Posts: 1 |
I'm using TD Ameritrade as my broker, after starting up SC i receive initial pricing but data doesn't update any further. I've verified that I'm using the correct streamer address: streamer-ext-bin-tx.tdameritrade.com. I'm trying to stream ES futures, please advise if there are further steps needed to have instantaneous streaming data.
[2019-01-29 20:37:28] |
We ran a test and did not see a problem but we did not use the streamer address override setting. It is not needed in newer versions of Sierra Chart. We are going to put out a new release later today which we will want you to test connecting to Ameritrade and see if there still is an issue. This will be version 1866. In that version the Global Settings >> Data/Trade Service Settings >> Service Settings >> Streamer Address Override setting needs to be set to nothing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-29 20:39:10
