Date/Time: Sun, 12 May 2024 05:42:02 +0000
Vertical Line to divide Overnight from Day Session
View Count: 2953
[2019-01-14 20:26:18] |
User718585 - Posts: 32 |
Is there a way to add a Vertical line on the charts that divide the chart between the overnight session and the Day session? Thanks |
[2019-01-14 22:49:13] |
Yes there are different options for this. Refer to: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-15 01:50:06] |
User90125 - Posts: 715 |
Try setting your Session Times to show both the overnight session and day session, as needed. Chart Session Times: Session Times Then you can add your Vertical Grid lines at Session Start or Start of Trading Day, as you prefer. https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#VerticalGridLinesAtEvery |
[2019-01-15 05:21:57] |
Merlin - Posts: 81 |
The problem with using the Vertical grid lines for the session dividers, is that that only works if you don't want to use the vertical grid for anything else. Personally I use tick charts (Sierra calls them "Number of Trades Per Bar"), and I like to set the vertical grid to a number of minutes, so I can still see an indication of how price is moving from a time perspective. So I use the "Time Line" study to mark the session start and end times - Time Line . This also allows me to make the session divider lines a different color than the time-based vertical grid lines. Works great! |
[2019-01-15 13:54:16] |
Thats awesome. Thanks Merlin
