Date/Time: Mon, 06 May 2024 04:30:31 +0000
Chart Values Tool on other charts?
View Count: 1038
[2019-01-11 21:05:20] |
Critcendo - Posts: 11 |
Hi, For some reason today when I use the chart value tool it appears on all other charts in the same chartbook. For example, if I have the chart values tool on .7217 for /6A, it will appear on all other charts in the chartbook for that same value. Regardless of symbol. Is there a way to disable this? It just started happening, unsure of what I changed. Thank you! Example attached |
[2019-01-11 22:13:38] |
It looks like the option for the Global Cursor has been turned on. Refer to the following: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
