Date/Time: Mon, 29 Apr 2024 10:35:35 +0000
Emini TPO chart settings
View Count: 961
[2019-01-11 16:57:12] |
User919585 - Posts: 6 |
Hi, I have a problem with the ES mini TPO settings. My time is Brussel time so ES opens in my country at 15:30hr I can't get the right settings for the TPO in time. Now I have open time at 15:30 and end next day 15:29hr but now I am not getting the TPO from the fridays. So can anybody advice me how I should adapt time to the ES mini in the settings? Already thanks a lot, Anita Date Time Of Last Edit: 2019-01-11 16:57:34
[2019-01-11 22:31:35] |
It sounds like you do not have the Time Zone for your chart set correctly. If the Time Zone is set to Brussels, then setting the times as you have (15:30 - 15:29) should work fine. Refer to this section to help you make sure your time zone is set correctly: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-12 11:28:55] |
Hi, Thanks for your answer. Timezone is set to Brussels but still I have no fridays on my TPO See also attachment Already thanks, Anita |
TPO timezone.PNG / V - Attached On 2019-01-12 11:28:09 UTC - Size: 34.01 KB - 275 views |
[2019-01-13 17:48:33] |
Make sure the chart is set to load weekend data: Chart Session Times: Load Weekend Data Setting (Chart >> Chart Settings >> Session Times) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
