Date/Time: Tue, 15 Jul 2025 19:25:37 +0000
Is there a way to display just the current session?
View Count: 1271
[2019-01-08 07:47:10] |
User814219 - Posts: 38 |
I'm using the cum delta bars - volume study with Reset at start of Trading Day set to 'Yes.' The problem when I go to chart settings and set '# of days to load' to '1' is that it seems to be based on date rather than session. So even when I set '# of days to load' to '1', since a day will often contain two different sessions, it shows two sessions worth of chart data. This is a minor annoyance when a new session starts and the cum delta bars - volume study's scale for the new session is compressed due to the previous session's cum delta still being within view and the cum delta study being reset to 0. I understand the easy way to solve this would be to simply set 'Reset at start of Trading Day' to 'No' but having the chart only display the current trading session would be more clear. Thanks. |
[2019-01-08 16:13:49] |
John - SC Support - Posts: 40908 |
You just need to adjust the Session Times as you require: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
