Date/Time: Thu, 16 May 2024 02:59:34 +0000
How to trigger chart update / calculation?
View Count: 1074
[2019-01-07 18:25:18] |
33818 - Posts: 30 |
Apologies if I've missed this in documentation & searches. Although I've found the GetBarHasClosedStatus function, is there a simpler way (whether study, spreadsheet setting or otherwise) to trigger a chart update / calculation from another chart's bar close? Example: -> Range chart #1 and Time chart #2 -> recalculate chart #1 ONLY upon bar close on chart #2 |
[2019-01-07 19:30:02] |
What you will want to do is overlay the data from chart #2 onto chart #1. And any updates on chart #2 will trigger a calculation in chart #1. But not a full recalculation. Use this study: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-07 23:08:18] |
33818 - Posts: 30 |
Thank you. I was using the Study Price Overlay Study and actually need a full recalculation that uses the accumulated (blanks filled with last value) data.
[2019-01-08 03:22:50] |
You can programmatically cause a full recalculation with: ACSIL Interface Members - Variables and Arrays: sc.FlagFullRecalculate sc.RecalculateChart() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-08 04:55:15] |
Sawtooth - Posts: 3997 |
You might also look at this: Kiwi Resync Study - Memory leak? |
