Date/Time: Thu, 16 May 2024 02:31:03 +0000
Displaying Candle Open, High, Low, and Close
View Count: 3190
[2019-01-07 02:23:25] |
User116783 - Posts: 84 |
Hi, Easiest question of the day: When hovering over prior daily candlesticks, how do you display their Open, High, Low and Close? For example, in the attached chart, the cross-hair is over 12/17. How do I display the OHLC for this day? Thanks, ZS Date Time Of Last Edit: 2019-01-07 02:52:16
2019-01-06_21-43-20.png / V - Attached On 2019-01-07 02:47:00 UTC - Size: 33.75 KB - 548 views |
[2019-01-07 08:21:13] |
Refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-08 01:34:10] |
Thanks for the response. I opened the chart values window but it took up a little too much space on my chart. Is there a way to display OHLC values for the candlestick you're hovering over at the top of the chart (see attached image)? ZS Date Time Of Last Edit: 2019-01-08 01:39:27
2019-01-07_20-26-53.png / V - Attached On 2019-01-08 01:32:35 UTC - Size: 52.08 KB - 553 views |
[2019-01-08 01:49:22] |
Ok, I found the compact tools value window, which is an improvement. However when I click on the chart, it disappears. Then reappears when I click on the chart again. Is there way to fix it into place where it won't vanish? EDIT: Never-mind, I found Global Settings >> Tool Settings >> Chart Values >> Keep Compact Tool Values Window Always Visible With Tool :) ZS Date Time Of Last Edit: 2019-01-08 01:54:26
[2019-01-08 03:11:23] |
Well not so fast it seems, I've reached an impasse. When selecting the pointer tool, the Compact Tool Values Window disappears. My tool settings are in the attached picture. I have tried to change the Action When Other Tools Selected to both "Always on when using other tools" and "Always enabled when using other tools." However neither worked. The Compact Tool Values Window still vanishes after selecting the pointer tool. ZS Date Time Of Last Edit: 2019-01-08 03:13:07
2019-01-07_22-10-31.png / V - Attached On 2019-01-08 03:11:15 UTC - Size: 85.52 KB - 342 views |
[2019-01-08 05:38:44] |
You need to use the Chart Values tool at least. It will not display when Pointer is selected.
