Date/Time: Sun, 19 May 2024 10:20:46 +0000
Lock text to position on the chart? When I scroll up or down the text moves to new price
View Count: 1100
[2019-01-03 15:04:36] |
User249672 - Posts: 1 |
I want to text to remain at the price levels where initiated. but when I scroll up and down text loses its position on chart
[2019-01-04 10:05:24] |
Assuming that you are using the text tool drawing options, then it sounds like you have used the option for Stationary Text, but you want to use the Type Text Drawing Tool instead. With the Type Text Drawing Tool, the text will keep its position relative to the price and time, whereas the Stationary Text keeps its position relative to the monitor and does not move when the graph is moved. Refer to the following documentation for more information: Chart Drawing Tools: Type Text | Stationary Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-04 10:05:54
