Date/Time: Sun, 05 May 2024 11:03:44 +0000
[Programming Help] - horizontal bars diagramm
View Count: 1080
[2018-12-31 14:16:53] |
MD236 - Posts: 28 |
Hi, since a few days I'm struggling to create a horizontal diagramm. I've no idea how to do this and can't find examples showing this. I read here Chart Studies: Horizontal Profile (ACSIL: DRAWSTYLE_HORIZONTAL_PROFILE) but do not understand how to plot at price X a value Y. I want to show the volume of the actual bar for each pricelevel as horizontal bar at the right side of the bar, but with DRAWSTYLE_HORIZONTAL_PROFILE I'm not able to draw from the right side, how is this done within the numbersbar study or volume profile? Can you provide me a with a working example please, I would be very happy to step forward with my programming experience in Sierra |
[2018-12-31 21:03:04] |
You need to use the Volume by Price study. Refer to the settings here for this: Volume By Price Study: One Volume Profile per Chart Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-01 10:36:40] |
MD236 - Posts: 28 |
Thanks for the really fast answer and a happy new year. I know this study but I want to realize this kind of diagramm from ASCIL because I want to display pulling and stacking and delta volume. I tried this code to display how often the same close appears: SCSFExport scsf_test(SCStudyInterfaceRef sc)
I attached the result. My questions here are:{ SCSubgraphRef sg1 = sc.Subgraph[0]; if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "test"; sc.GraphRegion = 0; sc.AutoLoop = 0; // manual loop sg1.Name = "BidVolume"; sg1.DrawStyle = DRAWSTYLE_HORIZONTAL_PROFILE; sg1.PrimaryColor = RGB(247, 77, 68); return; } for(int i=sc.ArraySize -10;i< sc.ArraySize;i++) sg1[i] = sc.Close[i]; } 1. how can I place the diagramm on the right edge of the chart 2. how can I setup it so it use only say 20% of the chart area? After this simple use I want to display the delta per price (I know how to get this values) like a volume profile but I need to know how to plot the delta per price because this is now working: sg1[price]=deltaValue;
[2021-03-01 10:45:29] |
MD236 - Posts: 28 |
2 years ago I'd posted my answer to my original problem, since this time I found no solution and also no example in your documentation. Do you have really no hint how to solve my problem? Thanks |
