Date/Time: Thu, 29 Oct 2026 09:53:48 +0000
Inset Window Question
View Count: 1008
[2018-12-27 20:03:55]
User909406 - Posts: 4
Greetings,
Is there a function whereby to "lock-in-place' a smaller "inset chart" overlaid on a larger Main Chart? I would like to display and not lose it by working on the larger chart...See snapshot
Thank you...David
imageinset window.jpg / V - Attached On 2018-12-27 20:02:53 UTC - Size: 43.14 KB - 366 views
[2018-12-27 22:39:44]
The closest that is available is this:
Study/Price Overlay Study
[2018-12-28 19:22:47]
What you can do is create the chart you want to have as the inset, and then detach that window from the main Sierra Chart and then set that detached window to Always on Top.
Refer to the following sections for each of these steps:
Detaching and Attaching Chart Windows: Detaching a Chart
Detaching and Attaching Chart Windows: Setting Detached Chart to Be Always on Top
Also, if you want to be able to view the inset window regardless of the Chartbook selected, then refer to this option:
Detaching and Attaching Chart Windows: Setting Detached Chart to Always Be Visible
And finally, if you want to minimize the information on the inset window, you can remove the title bar and scroll bars. Refer to the information here:
Chart Menu: Show Title Bar (Chart menu)
Chart Menu: Show Scrollbar (Chart menu)
Chart Menu: Show Menu (Chart menu)
