Date/Time: Mon, 20 May 2024 00:54:46 +0000
Custom Symbol
View Count: 971
[2018-12-26 18:11:16] |
anouar6869 - Posts: 13 |
I tried to create a custom symbol with ratio operator using data from two symbols but it return always a value for difference. I used currency pairs and index from Fxcm data feed. It is possible to create Custom spread ratio from 2 currency pairs with your new Custom Calculated Symbols? Thanks |
[2018-12-26 18:48:00] |
Yes it is possible and here is the documentation: Custom Calculated Symbols Make sure you are running version 1853. Tell us the exact symbol you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-26 18:48:11
[2018-12-26 19:50:56] |
this is the symbol I used {AUDJPY}/{GBPUSD} It return 77,.. which is the difference value. Yes I'm using v 1853 Date Time Of Last Edit: 2018-12-26 21:06:56
[2018-12-27 00:28:45] |
Okay we see the problem. This will be solved in the next release.
