Date/Time: Fri, 03 May 2024 03:02:47 +0000
quantity trouble
View Count: 1584
[2018-12-14 17:50:08] |
1234567 - Posts: 42 |
Im have trouble with increasing my trade 1 to 100, with attach trade widow to chart and trade activity log. Its doesnt show on trade activity log . how do i know its doing it the right quantity. And how do i fix it. Thank you
[2018-12-14 17:55:53] |
Are you referring to manual or automated trading?
[2018-12-14 19:48:02] |
yes im using automated trading
[2018-12-15 23:03:12] |
Okay are you using the Spreadsheet System for Trading Study or ACSIL?
[2018-12-15 23:49:39] |
is not a custom study, is just an normal study(F6). i try too see it on Trade Activity Log(Ctrl-Shift-A). step (1) im not connected, step (2)i run the AutoTrade System Bar Based Backtrest, step (3) Trade Activity Log(Ctrl-Shift-A) and when i look to Trade Activity Log(Ctrl-Shift-A) the Quantity is always just 1 i have Attach Trade Window To Chart and i have adjusted trade size to 120 but it did not change in the Trade Activity Log(Ctrl-Shift-A). please tell me what im doing wrong and thank you btw im new to sierra chart.
[2018-12-17 05:40:51] |
Okay, but are you using the Trading System Based on Alert Condition study:? Trading System Based on Alert Condition In this particular case make sure the order quantity is being set through the correct Trade Window: Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-19 01:46:49] |
the trade quantity is not up dating. i have do with you recommend and did not work.
[2018-12-19 01:47:37] |
what else should i do?
[2018-12-19 19:24:56] |
We really have insufficient information from you. Provide the chart you are doing automated trading from by following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-19 20:37:59] |
is there anyway reset to default settings for the whole system/software
[2018-12-20 05:52:29] |
Yes but really it is best that we get the chart so we can help you with this directly. But if you want to reset Sierra Chart to a default state, refer to: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-20 19:54:20] |
how do I increase my quantity size.
[2018-12-20 19:57:53] |
every time try to increase my quantity in DOMs, it dose not show in Trade Activity log. why is that?
[2018-12-20 21:51:57] |
Sawtooth - Posts: 3992 |
If you are using the Spreadsheet System for Trading study, you MUST use cell J26 for the order quantity. (This spreadsheet study overrides the Trade Window's order quantity.) If J26 is blank, the order quantity defaults to 1. Spreadsheet Systems, Alerts and Automated Trading: Order Quantity [J26] |
[2018-12-20 22:32:45] |
Thank you Tom. Hopefully that answers their question. We just wanted to make sure we know exactly what study they are using for automated trading.
[2018-12-20 23:59:29] |
the (J26) keep go back to blank, and in the "Trade Activity Log" just say 1 for quantity, but in the DOMs say 100 it does show up anywhere 100 Quantity size. I only have add add the "Spreadsheet System for Trading" to my "Chart Studies". why is that and how do i fix that. i have followed everything that that you have suggest. but i still don't know what doing on. please thank you |
[2018-12-21 18:19:30] |
why is the in Spreadsheet System (J26) not working? help thank you
[2018-12-21 18:37:06] |
In the Spreadsheet System for Trading study, set the Formula Source Sheet Number Input to 0: Spreadsheet Study Inputs: Formula Source Sheet Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-21 21:46:11] |
still dose work, why is that?
[2018-12-21 22:41:50] |
Hello?
[2018-12-21 23:33:41] |
We will need to help you with remote assistance at this point. This is going to be the most efficient way. Would you be available this weekend? And can you make sure your current telephone number is set here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-21 23:33:46
[2018-12-21 23:57:39] |
12-22-2018 im available after 2:00pm and on sunday im available 11:30am - 5:30pm BTW i have TeamViewer that might be easier so you can do it - see it the problem. and my phone number is the same. thank you
[2018-12-22 21:58:52] |
please give me a call when your ready. thank you
[2018-12-24 04:51:40] |
hey im free on 12-24-2018 @ 1:00pm-7:30pm my phone number is the same, for that remote assistance at this point. thank you
[2018-12-24 19:26:21] |
hello im still here. thank you
