Date/Time: Mon, 29 Apr 2024 09:49:26 +0000
SC Exchange Data Feed
View Count: 593
[2018-12-14 08:31:39] |
trad - Posts: 23 |
Will SC Exchange Data Feed work with Sierra Chart Pkg 5 provided by AMP futures? And will sierra feed work with Sierra Chart (aka InfinityAT) platform provided by infinity futures? |
[2018-12-14 09:30:21] |
The answer is yes in both cases.
[2018-12-14 10:51:02] |
trad - Posts: 23 |
Thank you. At the moment, I am on a trial account with infinity. The drop down options is grayed out and I cannot pull it down or edit it. What could be the reason for it? Is this issue limited to demo accounts? (I also cannot use the recommend image upload method to upload it because opening up that dialog box naturally locks up rest of the UI.) |
Capture.PNG / V - Attached On 2018-12-14 10:46:54 UTC - Size: 33.07 KB - 258 views |
[2018-12-14 18:26:52] |
This is okay because the Sierra Chart Exchange Data Feed works when Sierra Chart is configured to work with Transact and other trading services. Just follow through the step-by-step instructions here: Sierra Chart Exchange Data Feed: Setup Instructions And refer to: Sierra Chart Exchange Data Feed: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-14 18:27:08
[2018-12-15 04:53:57] |
trad - Posts: 23 |
Damn! That is one well written article. Great job. |
