Date/Time: Sun, 05 May 2024 12:35:21 +0000
DOM on chart & extract data
View Count: 565
[2018-12-13 17:12:20] |
Superbowl - Posts: 12 |
Hi team of sierra chart, I have two problems : - the first is that the dom on the chart can not be moved to another window, so I would have to be able to move it to the 'chart region' of my choice, ie chart region number two, without having to use another chart to display the DOM, thanks for allowing this setting this would be very useful. - I would like to extract a data present in a chart and to be able to use it in another chart, not with 'text display for study of chart' but extract the data to be able to use it for calculations and automatism on another chart, can please tell me if it is possible to remedy or, if there is already a solution to tell me the chemion to take. thank you very much for the help you can bring me and also the possible update you will do. Looking forward to a next answer. Thank you so much for what you have done, and the infinite possibility that you allow us to do. cordially |
bandicam 2018-12-13 18-10-00-319.jpg / V - Attached On 2018-12-13 17:11:15 UTC - Size: 173.33 KB - 206 views |
[2018-12-13 18:38:36] |
You can use the Study/Price Overlay study to access price or study data from one chart in another chart: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-13 18:39:11
