Date/Time: Tue, 07 May 2024 13:40:56 +0000
Backtesting - Trade List with Spreadsheet data
View Count: 689
[2018-12-13 15:28:04] |
User513228 - Posts: 41 |
Hi, I want know if is possible do backtesting and get trade list with data from spreadsheet for every single trade. Or is some way get this data ? I want know value of RSI, Stochastic, ... and every indicatorĀ“s value from my spreadsheet in time when trade was opened |
[2018-12-13 19:24:29] |
This is not supported. To some extent this can be done with this Text Tag feature though: Spreadsheet Systems, Alerts and Automated Trading: Support Order Text Tag Cell Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-14 09:15:32] |
I updated my sierra, set "Support Order Text Tag Cell" in Spreadsheet Study to Yes. But it doesnt work when i try using formula. I can see this cell in Notes only when i use some text but when i use for example " =$BA$3 " field in Notes is empty then.
[2018-12-14 09:32:29] |
Convert the number to text with this function: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#TEXT_Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
