Date/Time: Sun, 28 Apr 2024 21:01:17 +0000
Custom indicators
View Count: 2496
[2018-12-12 22:57:36] |
arruga - Posts: 249 |
Hi there New to SierraChart here. I'm used to code in TradingView. Is it possible to code in SierraChart daily ATR lines, which are hztal levels calculated dynamically during the day off of the current day's low and high and the values of ATR on the previous day... is it possible to do such a thing in SierraChart? Could you point me to some link with guidance on this? Many thanks |
[2018-12-14 07:34:17] |
Refer to: Average Daily Range Daily Range Bands Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
