Date/Time: Sun, 19 May 2024 05:23:33 +0000
Not able to connect to CQG/AMP
View Count: 597
[2018-12-12 22:11:54] |
User429197 - Posts: 1 |
Hello I have submitted logs for this particular issue. The AMP rep verified proper activation on their end and this was working fine earlier this week. Hello I am not able to connect to my AMP CQG connection I am getting the following error message "Windows Error code 10061: No connection could be made because the target machine actively refused it" I had an AMP technician do a full uinstall/reinstall and the same problem persist. Is there anything that is causing this issue? |
[2018-12-12 23:44:13] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
