Date/Time: Sat, 04 May 2024 16:10:16 +0000
feed disconnecting
View Count: 509
[2018-12-11 19:54:11] |
User254425 - Posts: 3 |
Yesterday my feed started disconnecting about once a minute. It can be reconnected via File: connect to data feed but it just disconnects again in a little while. This has persisted and continues through today
[2018-12-11 20:56:50] |
We want you to restart Sierra Chart and enable the Force Login option: Sierra Chart - Software Login Instructions: Forced Login Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
