Date/Time: Fri, 03 May 2024 06:22:18 +0000
Mid-point line...
View Count: 1674
[2018-12-11 15:20:17] |
User629089 - Posts: 93 |
Hi, Is there a way to add a mid-point line to a chart for example to an RTH session that updates throughout the day and displays like a moving average line? Thanks |
[2018-12-11 19:40:19] |
Depending on what you want in terms of the mid-point, you can probably find what you are looking for using the Daily OHLC study. There are subgraph options for OHLC Average, HLC Average and HL Average. Follow the instructions in the documentation to get the current day updates: Daily OHLC And you will want to set the Draw Style for the subgraphs you do not want to Ignore and the Draw Style for the Subgraph(s) you do want to either Line or Dash. For information on setting the Draw Style, refer to the following: Chart Studies: Subgraphs Tab >> Draw Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
