Date/Time: Sat, 18 Jul 2026 06:41:21 +0000
Commission cost instruction improvement
View Count: 2233
[2013-11-07 03:29:44]
User26059 - Posts: 19
The Global settings instructions do not explain exactly how to set commission cost only how to turn it on or off. this additional info would be helpful.
In order to set the commission amount you have to go to Chart settings/ Edit Global Symbol Settings/ Additional/ Round Turn Commission in order to set commission cost.
[2013-11-07 08:26:12]
Are you referring to the Trade Activity Log documentation?
[2013-11-07 19:08:32]
I never found documentation to show me where to set the commission amount anywhere, just how to turn on and off the calculation of the commissions.
[2013-11-09 02:32:20]
We have looked at the documentation for Use Commission setting on the Trade Activity Log in the Controls section for the Trade Activity log:
http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#Controls
It is thoroughly documented. We did review the documentation and make a couple of changes and additions now. However, it did say how to set the commission value.
