Date/Time: Tue, 07 May 2024 14:50:14 +0000
Please Fix: Tool Price Retracement (Fibonacci)
View Count: 1972
[2018-12-08 00:58:30] |
User722856 - Posts: 78 |
Dear Sir or Madame, I think the Tool "Price Retracement" needs a setting, where the User could choose whether he want's to use the automatic detection of "down / up sloping". The Problem is that you cannot freely choose at which Price level the 0% (start of the price move) should be, and on which Price Level the 100% (end of the price move) should be, because of the automatic behaviour in Sierra described bellow: If the line is down sloping, then the retracement lines will move upward starting from 0% at the bottommost point and the percentages will increase from this bottommost point.
If the line is up sloping, then the retracement lines will move downward starting from 0% at the topmost point and the percentages will increase from this topmost point. As stated here: Chart Drawing Tools: Price Retracement (2 point) | Price Expansion (2 point) | Price Projection (3 point) Tools What i want to achieve is the following behaviour and are Crucial to have an Edge with Fibo-Retracements: Problem-1-in-Sierra: If i set the Retracement as shown in the picture "fibo_retracement_down.png" in Sierra, then the retracement lines will always move upward and the User has no chance to change this. Problem-2-in-Sierra: If i set the Retracement as shown in the picture "fibo_retracement_up.png" in Sierra, then the retracement lines will always move downward and the User has no chance to change this. Also the SWAP Anchors feature does not solve this, which is also strange. Could you implement / disable this automatic behaviour in Sierra please - so that the User has freedom how to draw the retracements ( like shown on my attached pictures). Thank you very much. Best Regards Date Time Of Last Edit: 2018-12-13 19:12:28
fibo_retracement_down.png / V - Attached On 2018-12-08 00:49:27 UTC - Size: 17.13 KB - 566 views fibo_retracement_up.png / V - Attached On 2018-12-08 00:49:36 UTC - Size: 10.4 KB - 446 views |
[2018-12-13 18:48:12] |
Dear Sir or Madame, I see that my post was marked as “User Discussion”… I thought The Sierra Chart you see today was hugely influenced by user-submitted ideas, suggestions, and contributions. So this is it, no chance of any official statement? Any Feedback on this request would be appreciated. Thank you very much. Best Regards Date Time Of Last Edit: 2018-12-13 19:14:33
[2018-12-13 23:10:34] |
We have never had anyone ever ask about this before, at least we cannot remember and we are not in a position to be able to be able to support this anytime soon. We really just cannot help.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-01 05:16:47
[2018-12-13 23:43:46] |
Now one thing you can do is change the slope of the line in order for the retracement levels to function opposite of the way they currently do. And then you can set the Chart Values tool to be active with other tools through Global Settings >> Tool Settings >> Chart Values and use the horizontal chart values line to assist with determining the price level you want to set the endpoint at in relation to a bar high or low. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-13 23:44:55
[2018-12-13 23:45:54] |
Or possibly we could just add an option to allow the direction to function in the opposite way but that would be an additional cost if you want us to develop this.
[2018-12-16 19:58:34] |
Dear Sir or Madame, Thank you for your response, really appreciate it! Or possibly we could just add an option to allow the direction to function in the opposite way but that would be an additional cost if you want us to develop this.
I think that this would be a perfect solution. How much additional cost this would be? We can talk in private if you prefer. Thanks. Best regards |
[2019-01-01 05:18:19] |
Swapping the anchors will not help. In response to: I think that this would be a perfect solution. How much additional cost this would be? We can talk in private if you prefer. We can do this for 85 USD: Or possibly we could just add an option to allow the direction to function in the opposite way but that would be an additional cost if you want us to develop this. You can add the credit here:https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-01 06:14:00
[2019-01-01 18:42:03] |
Dear Sierra, Credit of 85 USD has been added to my account. Please implement the development as discussed above. Thanks. Best regards Date Time Of Last Edit: 2019-01-01 18:43:04
[2019-01-02 22:02:25] |
We will follow-up with this as soon as possible.
[2019-01-09 20:17:50] |
Update to pre-release 1858 following these instructions here: Software Download: Fast Update In the Global Settings >> Tool Configurations >>Price Retracement tool dialog there is a new Option named: Reverse Percentages That can be enabled and will apply to the next drawn retracement drawing and can be modified on an existing drawing. Let us know if that meets your requirements. If there any issues or limitations just let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-09 20:19:13
[2019-01-10 10:25:42] |
Dear Sierra, Thank you for implementing this. Quick Test: Looking very good so far!!! I will test it intensive in the next days, weeks and report any issues or limitations. Best regards |
[2019-01-19 09:26:52] |
Dear Sierra, After intensive Tests I confirm that the tool is working Superb. No issues or limitations found. Thank you very much for implementing this. Best regards |
[2019-01-19 09:37:45] |
Okay that is good. Glad we were able to work this in being we are extremely busy.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-19 09:38:27
[2019-06-21 20:32:12] |
hurleydood - Posts: 15 |
Is there away to prevent the anchor percentages from automatically swapping? I would like my starting anchor to always be 100% regardless of the slope. This is the default behavior for every platform.
Date Time Of Last Edit: 2019-06-21 21:03:46
[2019-06-24 22:53:01] |
We will have to see about adding an option for this. So the first point would be 100%.
[2019-06-26 18:02:56] |
Thanks. I see this feature now on 1940 but it doesn't seem do do anything. The first point flips to 0% or 100% depending on slope.
[2019-09-06 05:13:25] |
User737758 - Posts: 7 |
Is there a way to export file configs of individual/collective configs [ located at Global Settings >> Tool Configs ] for use at a new instance of sC platform on a new PC ? |
[2019-09-06 16:16:26] |
This is in the Sierra3.CFG file. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
