Date/Time: Fri, 03 May 2024 15:06:42 +0000
joigbear
View Count: 743
[2018-12-03 09:47:28] |
User661434 - Posts: 27 |
These values are not easy to read when they are higher numbers, is there a possibility to add a THOUSAND SEPARATOR in this study? Thank for reading this and helping me out, if possible.... |
[2018-12-03 20:13:28] |
The first thing you need to do is you need to update to the current version of Sierra Chart. Refer to: Software Download: Fast Update And then tell us what particular Study you are referring to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-04 13:23:22] |
Thank You for Yor reply, I did the update now. I am referring to the 1) Number bars calculated values Study See picture in attach I am struggling to read this number correctly, A thousand separator would be very helpfull 2) in the number bars study, bidvol x askvol study, See picture in attach It would be nice to have the possibility to abbreviate like you can see and do it in the Times and sales windows for example 100000 to 100K ect... a thousand separator would help too. Its ingeneral a question to make large numbers more readable. Thanks |
Thousand separator needed.jpg / V - Attached On 2018-12-04 13:18:36 UTC - Size: 33.65 KB - 297 views numbers bars difficult to read.jpg / V - Attached On 2018-12-04 13:22:19 UTC - Size: 102.95 KB - 318 views |
[2018-12-04 18:34:43] |
For the Numbers Bars study you need to set this Input to Yes: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_UseLargeVolumeNumberFormatting We will make sure we add the same input for the Numbers Bars Calculated Values study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-05 13:19:06] |
Awesome, I have adjusted it for the number bars, it gives me a lot of comfort now.... Thanks, I am looking foraward when these settings would be available in the Numbers Bars Calculated Study too, thanks a lot.... |
[2019-02-02 15:16:05] |
Hi, Regarding the Numbers Bars Calculated Study, would it still be possible to make the Rounding to thousand units possible? My 'table' is pretty unreadable when high numbers occur - see example image in attach (just like in the - fantastic - number bars itself, where the Rounding is possible) I am sure that a lot of people would be helped with this function Thanks again for reading my stuff :D |
number bars table.JPG / V - Attached On 2019-02-02 15:13:14 UTC - Size: 20.7 KB - 224 views |
[2019-02-02 17:04:07] |
John - SC Support - Posts: 31341 |
Yes, this is still on our short list to get done. We have just been busy with other tasks. We hope to get to this in the next few weeks.
