Date/Time: Tue, 30 Apr 2024 04:29:07 +0000
numbers bar - range bar - Jumping price / holes in bar
View Count: 862
[2018-11-29 22:04:57] |
sierrasimon - Posts: 51 |
Hi, it is happening in range bar chart, like in attached screenshot. I looked in Volfix, but there its normal. I use SC Data all services. How can I avoit this? |
Range bar Volfix.JPG / V - Attached On 2018-11-29 22:00:21 UTC - Size: 196.18 KB - 275 views Range bar SC.JPG / V - Attached On 2018-11-29 22:00:26 UTC - Size: 157.89 KB - 315 views |
[2018-11-30 05:24:59] |
Why would you expect to see complete trading activity back in September for the January 2019 crude oil futures contract? And in the other chart, you are looking at the October 2018 contract. You need to use the Continuous Futures Contract chart feature: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-30 05:25:42
[2018-12-03 14:03:48] |
I already activated continuous future contract chart. Any other Idea?
[2018-12-03 15:23:48] |
User907968 - Posts: 802 |
How sure are you of the data you are using for a comparison? The data you are showing in the SC screenshot corresponds to the inventory news on Sept 6, this kind of gapping behaviour would not be unexpected in the seconds immediately following the news. |
[2018-12-03 15:52:17] |
We do now notice you are using the Continuous Futures Contract option. Fully re-download the data for all contract months following these instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data If you still see the same result then the result must be accurate based upon the short range you are using and a very active moment in the market. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-03 15:52:40
[2018-12-03 16:44:45] |
Thanks. I redownloaded, but nothing changed. I thaught even in a very active moment, the price is moving continuos and not jumping. But i don't know what the market is able to do in reality. Maybe Volfix has a filter to not display the jumps. This jumps are causing wrong automatted trades. Therefore I would like to get a solution for that. Is it possible for you to put a filter on this jumps?
[2018-12-03 18:21:30] |
The problem is still unsolved, but I was confused about the time zone, volfix was using. So I updated the screenshot for the same time like SC.
volfix RB6.JPG / V - Attached On 2018-12-03 18:19:20 UTC - Size: 225.61 KB - 301 views |
[2018-12-04 07:48:52] |
We have examined this chart configuration using IQ Feed data and the result is the same: http://www.sierrachart.com/image.php?Image=154390957227.png What you see in SC is definitively correct. This volume fix is just simply wrong. If you want to have faith in something wrong you can go ahead and do that but they are just flat out wrong. That is just so overwhelmingly clear. You will only get perfection with Sierra Chart and Sierra Chart Exchange Data Feed and that is the basic fact. We know because we know intimately how everything works. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-04 07:49:25
