Date/Time: Sun, 05 May 2024 05:05:36 +0000
Data to donwnload only today
View Count: 520
[2018-11-28 01:34:32] |
User291336 - Posts: 4 |
Halo, how to set the download of "delete all data and download" for historical data limited to today only? I already try the below methods and it is still load 24 hours data 1. set the data to load under Chart->Chart Setting->Main Setting to 1 2. set the date range under from and to as today only under Chart->Chart Setting->Main Setting Date Time Of Last Edit: 2018-11-28 02:25:11
[2018-11-28 17:16:08] |
It sounds like you will want to adjust this particular setting: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
