Date/Time: Sun, 11 Oct 2026 07:56:28 +0000
[User Discussion] - Drawing box to mark candle and time on chart and indicator
View Count: 3735
[2018-11-28 01:09:58]
User651753 - Posts: 77
as an example
how do I make a drawing to overdraw all charts and sub chart?
Eg. i want a green box to go over the chart and then bottom indicator.
http://www.sierrachart.com/image.php?Image=1543367004831.png
[2018-11-28 08:43:05]
User371906 - Posts: 141
User651753,
Wanted to ask you if Willy Wave Trend Indicator is available in SC studies with a different name as I can find it there?
Please let me know
Regards
g
[2018-11-28 17:28:52]
You need to use this Drawing tool:
Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle
You may also want to make sure the following setting is unchecked:
Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
Date Time Of Last Edit: 2018-11-28 17:31:17
[2018-11-29 05:57:40]
Thanks for the reply, it looks like Rectangle cant draw over 2 charts ( main chart + indicator )
but a vertical line can
[2018-11-29 16:31:19]
John - SC Support - Posts: 48169
A Rectangle certainly CAN be drawn on top of the other items in the chart. Be sure you have the item specified previously unchecked. Make sure you are unchecking the correct item, for Rectangles, Ellipses and Triangles, it is the one that states Draw Highlight Drawings Underneath Main Graph and Studies.
Also, if you want the rectangle to completely block what is behind it, then you need to set the transparency for the rectangle to 0. Refer to the documentation here for this:
Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle Configuration
[2018-11-29 21:07:57]
We think what you are asking about is that a Chart Drawing cannot span more than one Chart Region . This is correct. Other than the Vertical line tool.
Date Time Of Last Edit: 2018-11-29 21:08:04
[2018-11-30 07:24:48]
Yea , that fine ,
Ill just use vertical line tool .
is there another tool that is like "background" I could highlight the total area on the chart and another chart region like Vertical line tool ?
[2018-11-30 17:17:58]
No there is not.
