Date/Time: Sun, 28 Apr 2024 19:12:48 +0000
loading market depth data
View Count: 1130
[2018-11-12 08:26:34] |
User12089 - Posts: 350 |
it seems that the SC Historical Market Depth Study loads market depth files ONLY from the beginning of each month or to be more precise, from the last day of each month (the contract is always the same including its expiration date). Hence any older Market Depth Data remains unused Is that correct? And if yes is there any way to control it trough config setting |
[2018-11-12 18:14:12] |
This is controlled with this setting: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseNumberOfDaysToLoadMarketDepth But market depth data files for prior contract months in a Continuous Futures Contract chart we do not think are loaded. But we would have to check on that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-12 18:15:07
[2018-11-12 18:24:21] |
yes but .... the concrete example I have observed and is happening right now is that for all contracts expiring in Dec (Gold, ES, ESTX50 etc) the Market Depth data for Oct is not getting loaded in charts - it all starts from 31st Oct and carries over into Nov from there - an di do have Market Depth files for every day in Sep and Oct ....
[2018-11-12 19:23:43] |
What is this setting set to?: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseNumberOfDaysToLoadMarketDepth Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-13 13:40:44] |
I use "number of days to load" = 60 I do not use "use date range" - it is unchecked finally - I am getting the price bars for the entire 60 day period, however the Market Depth Data is absent for the same period, prior to 31st Oct ie its starts from 31st Oct even though I do have Market Depth files for the entire of Oct and even Sep |
[2018-11-13 18:46:38] |
To the right of the Days to Load setting there is a setting named "Market Depth". What is that set to? And is this a continuous futures contract chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-13 20:34:32] |
aaaaah got you - it was set to ... 10 .... thank you |
[2018-11-14 11:44:17] |
and btw WELL DONE!!! as usual the SC dev team has thought about everything and I do mean everything :-) It definitely makes a lot of sense decoupling the time ranges for the chart price and volume data from the ranges for Market Depth data ... the main benefit being performance and memory efficiency |
