Date/Time: Sun, 19 May 2024 16:25:54 +0000
question marking areas and levela
View Count: 1006
[2018-11-10 06:02:41] |
User183272 - Posts: 13 |
is there a way I can mark levels on a chart just based on the price for example let's use amazon as an example lets say I want to mark the levels 1715.20 and 17.12.20 on a one minute chart throughout the trading day rather than finding the level and manually writing a note or drawing a line, and flipping back in the chart to find them or writing them down..... can I input the two prices and have it marked throughout the chart as the day continues? and can I change these levels as my levels change? Thanks! |
[2018-11-10 14:15:53] |
RonW - Posts: 103 |
You might be able to make the “Trading Levels” study work for this.
[2018-11-11 02:18:24] |
Acro - Posts: 436 |
Another option is to use the spreadsheet study and just type those levels in the spreadsheet.
[2018-11-12 07:41:52] |
We recommend using the Horizontal Ray drawing tool for this: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line That drawing type can be set to display the price level and you can also set text on that drawing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-12 07:42:51
