Date/Time: Sun, 19 May 2024 00:37:10 +0000
Color Gradient the volume profile and a
View Count: 3887
[2018-11-09 17:49:20] |
User502498 - Posts: 33 |
I'm coming from Investor R/T where they have a Delta Shaded Volume Profile, and a "smoothed Delta" profile that takes the values from the VP and avg's them. Using the smoothed delta profile, it's very easy to see areas of support and resistance off the slope of the VP to the HVN. Is there anyway to get better color gradation in the VP on SC? I attempted to duplicate the smoothed delta, using a 3 tick avg, but it's not that clear. I attached two images. Thank you very much! This is from their site. https://www.linnsoft.com/techind/price-statistics Volume Profile Delta Shaded - distribution of volume at price and shades each volume at price bar according to the intensity of delta. Smoothed Delta (y) - Averages the delta for the nearest (y) bars and displays it as a value. |
SCVolProfDeltaShaded.JPG / V - Attached On 2018-11-09 17:47:35 UTC - Size: 28.84 KB - 906 views IRTVolProfDeltaShaded.JPG / V - Attached On 2018-11-09 17:47:39 UTC - Size: 17.15 KB - 722 views |
[2018-11-12 17:30:10] |
The only supported Volume by Price Volume bar coloring methods are documented here: Volume By Price Study: Bid Volume and Ask Volume Coloring Method Volume By Price Study: Color Code Volume Bars Based on Percentage of POC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-12 17:30:26
[2018-11-12 23:49:39] |
Another way to do this is to use the Numbers Bars study: Numbers Bars It supports volume profile type of background coloring and 8 different color settings. What you can then do is if you set the chart bars to the timeframe that you want the volume profile for, then you will have a volume profile for that timeframe. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-13 19:13:06] |
I was hoping to have the Volume by Price study able to use the coloring options from the numbers bar study. When I set the number bars study to 1-0-0 for a daily graph, I can't have it "on" the same window as a renko type chart. I was just hoping that the color gradient of the volume by price could be more granular, to emulate something like this attachment in capture.jpg. VP is the delta shaded volume profile, and SD is the smooth delta which just takes a tick above/below and does a avg. The closest I can get with SC is capture2, but I cannot gradient the colors. |
Capture.JPG / V - Attached On 2018-11-13 19:10:31 UTC - Size: 31.05 KB - 791 views Capture2.JPG / V - Attached On 2018-11-13 19:12:30 UTC - Size: 49.94 KB - 628 views |
[2019-02-21 13:36:40] |
User336946 - Posts: 37 |
I second this request to add these coloring options to the volume profile. It's not enough to use number bars since you can't fix the number bars study to the right of the screen.
[2019-06-24 19:03:23] |
User187881 - Posts: 2 |
Agreed - this would be great
[2019-06-28 05:48:38] |
NotIll - Posts: 118 |
+1 for this request
[2019-10-01 17:19:32] |
ycomp - Posts: 277 |
would be great
[2019-11-20 16:58:41] |
User830753 - Posts: 1 |
+1 more for this
[2019-11-20 17:06:01] |
nosast - Posts: 290 |
+1
[2020-12-24 08:46:28] |
@sstfrederik - Posts: 404 |
this is now done. Feel free to try it. https://sst.frl/smooth |
[2020-12-25 20:39:43] |
Trader&Hunter - Posts: 129 |
Amazingly Done!!
