Date/Time: Fri, 10 May 2024 20:46:32 +0000
Colouring the background of the value area
View Count: 615
[2018-11-05 14:26:18] |
Atlan - Posts: 7 |
Hello, As mentioned in the title, I am loocking for a way to colour the area between the high and low of the value area. I also added a picture to show you what I mean. Thanks and kind regards Atlan |
Value Area.PNG / V - Attached On 2018-11-05 14:23:26 UTC - Size: 8.17 KB - 258 views |
[2018-11-05 17:41:13] |
Refer to: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-05 18:36:44] |
Atlan - Posts: 7 |
Thank you very much. I was googling for about 2 hours and could not find it. Kind Regards Atlan |
