Date/Time: Fri, 17 May 2024 21:06:10 +0000
Limit 7 Symbols, but 20 Real-Time Symbols with futures and indices only?
View Count: 578
[2018-11-01 12:04:30] |
TedMar - Posts: 189 |
I subscribes 1.) 20 Real-Time Symbols 2.) Full CME Group (CME, CBOT, COMEX, NYMEX) 3.) Eurex with Market Depth there are futures and indices only, and in manual "Symbol Limits" i found this: If you have activated only futures and indices exchanges, then the symbol limit is 100 real-time symbols. Now i get Error "Limit 7 Symbols" Whats wrong ? Date Time Of Last Edit: 2018-11-01 12:05:48
[2018-11-01 17:20:33] |
Based on the exchanges you have active, you should have the full 20 symbol limit for futures. Reconnect to the data feed and see if you still have this issue: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-01 17:45:37] |
I reconnected many times bovor i made posting in Support Forum. but it works now. Thank You
