Date/Time: Sat, 18 May 2024 12:03:08 +0000
Mark Naked Bid/Ask Extremes
View Count: 705
[2018-10-26 11:15:21] |
infpz - Posts: 826 |
Not seeing this choice in the Numbers Bars study in version 1829 - will it be added soon?
[2018-10-26 18:03:37] |
Was this something that you previously requested? Can you provide us a simple description of what this is. It is not clear for us.
[2018-10-26 18:29:23] |
See here please https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_MarkNakedBidAskExtremes
[2018-10-26 18:32:36] |
Okay this is a mistake. That should not have been documented. It is in there for one particular group.
