Date/Time: Sat, 18 May 2024 05:24:33 +0000
pause all charts
View Count: 642
[2018-10-26 03:17:03] |
Willson - Posts: 176 |
How can all charts be paused then un-paused under manual control? Some time ago Kiwi provided a study to do just this. The purpose is to allow time for examination of multiple study conditions prior to placing orders. If no study is available, are there work-arounds such as pausing the internet connection, or disconnecting the data feed using SC controls?
[2018-10-26 17:50:45] |
You can certainly disconnect from the data feed: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#Connect Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
