Date/Time: Sat, 18 May 2024 14:44:52 +0000
constant stream of errors
View Count: 582
[2018-10-25 17:23:34] |
N!co - Posts: 140 |
hi all of a sudden i receive this constant stream of errors any idea what causes this ? Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:15:58 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:15:59 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:15:59 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:00 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:00 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:01 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:01 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:02 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:02 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:03 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:03 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:04 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:04 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:05 * Warning: Caught an exception during the processing of a timer event. Source: c_Chart::m_UpdateTimer | 2018-10-25 19:16:05 * |
[2018-10-25 19:25:56] |
Two things we want you to do are to update Sierra Chart: Software Download: Fast Update And then run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode See if that resolves the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-25 19:26:40
